uaEFI Ultra Affordable EFI
$100 fully assembled 6x6 standalone with DBW and WBO.
https://github.com/rusefi/uaefi
Re: uaEFI Ultra Affordable EFI
Now waiting for wideband cables and pigtails to be manufactured.
ykill
Post by ykill »
Good job! Pretty interesting at this price!
jevgienij
Post by jevgienij »
Optional EGR or EGT?
jevgienij wrote:
Mon Dec 18, 2023 8:09 pm
EGT, thank you for pointing out the typo!
joaodh
Post by joaodh »
I'm currently following various topics on the forum, and I'm contemplating converting my classic car to run on an ignition-controlled ECU.
Initially, I'll stick with the stock injection system (K-Jet :cry:).
My goal is to maintain the original look of the engine bay, so I plan to adapt the distributor with a trigger wheel.
Is this board suitable for use? I'm not a fan of the connector positions, for me will be better to have all pins on the same side. I might explore changing that.
Thanks for this fantastic project.
uaEFI is doing good! There is already one unofficial adapter see FB group. We've just merged preview of the official hellen-one module for uaEFI adapters see https://github.com/andreika-git/hellen-one/tree/master/modules/uaefi/
Chybber
Post by Chybber »
Hello I've made a simple box/case and lid with snap fit. It's real simple but should work ok
The board is fastend in with 4 m3 screws directly in the plastic And the lid is as mentioned snap fit, good tight fit so should not come loose.
I've only test printed in petg so I don't know if pla etc would work ( you have to test)
My print settings were
0.16 layer height
3 walls
6 top/bottom layers
Now working on first official adapter board so rev B had changes specifically for ease of adapter application
Kim has posted another enclosure on FB - https://www.thingiverse.com/thing:6498664
Mappie
Github Username: EDMaus
Post by Mappie »
Hi,
2 question 's :
Q1, what is the purpose of the Optional Can 2? or better, when would i need it? any example?
Q2, i recieved my JDY-33 bluetooth, can i just solder it in? or does it need programming first?
thank you.
Q1: I do not know. What's the purpose of CAN 1 or even what's the purpose of rusEFI?
Q2: just updated https://github.com/rusefi/rusefi/wiki/Bluetooth with references to recently updated tickets about all that
Random suggestion while unfortunatelly things are not perfect
gurov
Github Username: ggurov
Slack: ggurov
Post by gurov »
more mounting suggestions:
carrier board in a stock ECU case
able to close the cover:
pins into UAEFI molex connectors at almost straight angles:
for molex spacing, 3 pin connectors with middle pin removed:
Atlantis2013
Post by Atlantis2013 »
hello,
what is the copper weight for inner and outer ? both 1oz ?
best regards
Atlantis2013 wrote:
Tue Apr 30, 2024 11:10 am
probably, whatever is the default.
Atlantis2013
Tue Apr 30, 2024 2:21 pm
default is 1oz for outter and 0.5 for inner
Larspars
Github Username: larsnergard
Post by Larspars »
Hi
What componets do I need to populate CAN2 option? Cant find it in any BOM.
ludowrx974
Post by ludowrx974 »
I'm really sorry for this question, I'm a beginner. I was able to see the different documents on the UAEFI. Concerning the VR conditioner, is it able to work well with the civic (or dizzy) igniter?
ludowrx974 wrote:
Thu Jul 18, 2024 11:37 am
yes search gives https://rusefi.com/forum/viewtopic.php?p=49552#p49552
A nice enclosure https://github.com/Light-r4y/uaEFI_case
mpgmike
Post by mpgmike »
Looks like it works with the standard UAEFI (not the 121). Are they for sale for those of us who still don't have a 3-D printer? If so, how much?
mpgmike
Post by mpgmike »
AndreyB, the current UAEFI uses a TI SN74LVC4245APWR Logic Translator for U103. It is capable of sourcing and sinking 24 mA on the outputs. Spent some time and found a pin-compatible TI SN74LXCH8T245PWR capable of source/sink at 50 mA. I bring this up because I fried U103 twice trying to drive LS coils. Mouser single unit price for what you're using is $1.04, while the suggested replacement is slightly higher at $1.73. Here is a link to the data sheet: https://www.ti.com/lit/ds/symlink/sn74lxch8t245.pdf?ts=1743163518629&ref_url=https%253A%252F%252Fwww.mouser.com%252F
mpgmike
Post by mpgmike »
Out of curiosity I bench tested an LS coil logic circuit. I connected both grounds, but not battery voltage. Applying 5 volts to the signal drew less than 2 mA. I have no idea why LS coils burned up U103 two times.
Nice video
