Lowcost simple CAN dash esp32 uaDASH
diegort5
Re: Lowcost simple CAN dash esp32 uaDASH
Post by diegort5 »
Light_r4y wrote:
Mon Aug 11, 2025 6:51 am
diegort5 wrote:
Sun Aug 10, 2025 8:42 pm
Hi everyone,
I’d like to share the current progress of my uaDASH integration with an ESP32-P4 and a 1024x600 7inch LCD display. The project is about 60% complete — the main features are working, but the case/enclosure still needs to be designed.
Here’s what I’ve implemented so far:
External CAN Bus using an SN65HVD230 transceiver for direct communication with my rusEFI ECU.
Dedicated inputs for common dashboard warning lights, including:
Check Engine
Oil Pressure
Battery/Alternator
Turn signals (left/right)
High/Low beams
Handbrake
Seatbelt
Door open
Fully working bench test buttons for injectors and ignition coils
Help needed:
I’m currently trying to send a Start/Stop button command to a MicroRusEFI, but I get an error when sending it. I’m not sure if this requires creating a Lua script for that function. Any guidance or examples would be greatly appreciated.
Additionally, what are the possibilities of using free software to replace Squireline Studio, since after 30 days they charge for use? Given that there is another option, Squireline Studio, does anyone know if it is viable to continue with the project?
— Diego
Yeah Squireline Studio is not the best in this regard, it just happened that way and i started using it a lot. So now i have to merge screens programmatically. You can try "EEZ studio" (https://www.envox.eu/studio/studio-introduction/), it allows you to generate lvgl code, but i haven't used it myself yet.
If the Squireline Studio software is very expensive, I thought its price would be more user-friendly. Regarding the start-stop function, is it possible that you could guide me on how to integrate it into the microrusefi ? Thank you in advance for your time.
Light_r4y
Post by Light_r4y »
Use latest rusEFI firmware and check start/stop function in tune, i don't try this function, this AndreyB tested
Light_r4y
Post by Light_r4y »
DanielGaviria wrote:
Mon Aug 11, 2025 3:02 pm
Light_r4y wrote:
Mon Aug 11, 2025 6:36 am
Sun Aug 10, 2025 5:53 pm
Hey,
Do you have the SquareLine Studio project file with the settings screen?
I’d love to help improve the UI, but when I export it without all the elements, it doesn’t compile.
Settings screen had to be allocated to a separate project and then glued together in the code, the free version of the SquareLine Studio is limited in the number of widgets in the project. I probably later add in github repo
Thanks a lot for the reply!
I kind of figured you had to split the Squareline Studio project because of the widget limit, the unrestricted version is insanely expensive.
I’ll be waiting for the repository update!
I updated the repository with what SQ projects I could find on my computer.
madcribby
Github Username: na
Slack: na
Post by madcribby »
Would this hmi screen work with this project? i have one and a eps32 left over from another dash project i opted in for but the code was flawed.
https://nextion.tech/datasheets/NX8048P070-011C/
Andy_D
Post by Andy_D »
I've installed EEZ Studio, unfortunately it currently doesn't have an import function to migrate the SLS screens directly into it. Found some info about copying the compiled files into to the project file but so far haven't been able to get it to see them.
Am thinking the quickest way to use the software would be to just recreate the project. One advantage apart from it being open source is that it supports the 'meter' widget for making nice speedo & tacho's as well as functionality to use external instrumentation.
Andrey, If I did recreate the screens, is there also coding changes needed in other parts of the scripts to accommodate this ?
Light_r4y
Post by Light_r4y »
Andy_D wrote:
Mon Oct 13, 2025 3:30 pm
If the widget names match, everything will work. I haven't migrated to EEZ yet.
Light_r4y
Post by Light_r4y »
madcribby wrote:
Thu Oct 02, 2025 3:00 pm
It should work, but you'll need to configure the display driver correctly.
bbbrad
Post by bbbrad »
Looks perfect. But I'm just a simple guy. Is it a relatively easy thing to connect up to a say a uaefi. Do I need to be a computer programming genius? I'm ready to buy one.
Light_r4y
Post by Light_r4y »
bbbrad wrote:
Mon Oct 27, 2025 7:26 pm
if you from not Russia https://www.shop.rusefi.com/shop/p/uadash7
Andy_D
Post by Andy_D »
Light_r4y wrote:
Thu Oct 16, 2025 8:05 am
They don't, EEZ uses the LVGL standard protocol of lowercase & underscore as well as all screen exist in a single 'screens.c & .h' files, so the rest of the additional logic code will need to be added in & adjusted to suit. I think a better option is just to stick with SLS unless you want to rewrite it.
