First, I looked at the schematics and could only find R202 & R206 for IAT, and R201 & R205 for CLT -- all 4 are 680k resistors; 2 are pull-up to 5 volts, and 2 are pull-down to ground. I'm not very functional with Kicad, but tried to find the traces to follow (unsuccessfully). Can't find the 2.7k pull-ups!"the analog temp inputs have a 2.7k pullup to 5v. You could always wire your coolant sensor to a voltage input instead, which would probably work."
Secondly, I tried using AUX1 as a IAT input, but TunerStudio gave errors when I tried to use it in the Ignition section. I see the traces from the IAT & CLT inputs go to a bank of resistors, but about the smallest I can work with are 0603, and I can't read anything on them. Please offer some direction.
