It's basically a Solo 2 DL on steroids that runs Linux, works with a (react) mobile app for now, but I'll make a desktop one as well.
It uses M5 connectors. It's tiny but it fits well for motorcycle and go-karts where we lack space. Also nice when we want compact sensors.
Here a quick hardware list:
- Based on a T113-S3, runs Linux, custom bootloader
- STM32G0 for power management
- 8GB of eMMC storage
- 4" 800x480 Transflective LCD
- 4x M5 ports, bidirectional power, data over USB 2.0
- Power input from 5 to 24v, output fixed at 12v
- Programmable RGB led bar
- Waterproof
- Wifi ac/ax (AP/client mode), Bluetooth
- 3000mAh+ battery with fuel gauge
- USB signal switch on front port for easy debugging & maintenance
- USB-C OTG front port with power delivery
- Form factor compatible with Aim Solo 2, most mounts can be re-used
Why USB? It's cheap, fast and ubiquitous. We can do anything from a simple analog sensor, to a display or even controlling a gopro.
The idea is to create an ecosystem that can evolve and be customized while keeping it simple for users.
An online part would be nice as well, where we can post lap times/data and browse, compare them or watch live telemetry.
It's built with Kicad/Freecad and can be made via for about $100 on low qty. (incl case & lcd)
Case has been designed for molding and 3d printing.
It can also be used as a dashboard but I haven't done any work on the GUI yet. I'm considering LVGL.
Most of the software is in early stages except the power management and system stuff. It's mostly Golang and C.
Would anyone be interested in helping? It's a ton of work
I'm getting a few assembled boards from JLC end of the month, I'll keep you posted.
USB-C PD and 4 buttons on the top, 2x M5 on the bottom Runs on battery or permanent power, 2x M5 ports on the back With tempered glass
