Hi everybody!
I'm Gioele, an Italian almost mechanical engineer (just finishing my studies, i'm still at uni) with a strong passion for both old cars and newer technologies.
I've owned this Merc for 4 years now, bought with the payouts of my first side job and it has always been a pleasure to drive around.
2 years ago i started growing an interest in powertrain related affairs (i'm a chassis guy usually), and have been wanting to convert my car since then, initially to MS but then decided to go with rusefi since it was a far more affordable option.
So yeah, 2 years in planning, untill now, when i had 2 weeks off and the conversion finally begun.
this is the part list.
here's the UAefi wired into it's custom case, you can find wiring info in the attached PDF file.
Here's the lambda, CPS and toothed wheel mounted on the car; the bung for the o2 sensor has been tig welded in the nearest position to the cylinders as possible; the toothed wheel has been mounted on the stock vibration dampener after having it lowered by 5mm, so it's squeezed between damper and pulley. The CPS is placed at 0.8mm from the wheel which has ben turned on a lathe after being laser cut to achieve as little runout as possible.
Then it was the turn of the intake manifold, got it disassembled and cleaned, then modified to house the rail/injectors, MAP/IAT sensor as well as the TPS (which is giving me some issues right now, but lets go on).
here are some picture. the mounting for the throttle link and spacers have been manufactured using the infamous "eyemeter", a grinder and a lathe.
(i think i reached the max number of pictures on one message, keep scrolling)
Mercedes 190e M102 UAEFI conversion
Giobs
Giobs
Re: Mercedes 190e M102 UAEFI conversion
Ok, let's keep on rolling.
Now, everything assembled on the car: It was time to manufacture the harness and the coil support: .
The fun part sadly ends here, once i got it to start and idle well (it required a full day since i misconnected 2 spark plug wires) i was starting to taste the feel of getting the conversion done! but that's were some misterious issues started appearing.
First issue, my board is plagued by the 5v loop issue that is affecting other boards, but soldering the 10k resistance to wake up the regulator worked in solving this issue.
Second issue, while i was still troubleshooting the spark plug wires issue, i got an injector (B6 output) stuck open (output from ecu always grounded), from which i got an error in tunerstudio (which showed only once, never reappeared). and i found resistance R29 had gone from 4.7Kohm down to 0.7 Kohm for no reason that i can see (i work with some powertrain guys from the powertrain division of a formula student team, we usually use motec but the way the ecu was handled and tested was nothing out of the ordinary).
You can see here the measured voltage across the 12v and B6 pin (which wasnt active at the time of measuring). I since then switched the injector 1 output from B6 to B2 to continue to use the board, and did a 45 minutes tuning session with it, everything seemed to work fine untill, after a pause, i restarted the engine and in 10 seconds in i lost both cyl 1 (output B2) and cyl 4 (output B3) injectors output.
Now the ecu shows 5.5v across these pins, no errors and testing the outputs through software doesnt change the voltage measured.
the injectors all measure 16.something ohms.
I still have to investigate the issue, but i think i'll find other resistance shorted (maybe they were defective? idk).
anyway, attached the schematics and pinout, also for other users to maybe take inspiration if needed. If you have any kind of suggestion on what to check / change on it to make the board reliiable i'm all ears; i would happily buy another one (hoping for more reliability) but being in italy makes it kinda hard...
Anyway will have to figure it out since i need to get the car back on the road.
Thank you for your attention
https://github.com/rusefi/uaefi/issues/95
can you take a good photo of one of the injector driver chips? just want to confirm which part number your specific unit has. those are SOIC-8 looks like those are all on the back side
Giobs
Ok so, mercedes M102, 4 cylinder 8v engine with a fully custom wiring and UAefi, using wasted spark and batch injection since i have only a sensor on the crankshaft (VR), you can see the complete list of parts, and the wiring scheme on the forum.
Lets go directly from the first start (3 weeks ago), on the first board (rev E) which went mostly according to plans, a few issues regarding idle and the jumpstart required for the 5v rail, a few other things but it ran completely fine to be a first install and forst start. It kept running for at least 10 minutes before i shut it off to finish other works before tuning.
Then tuning started, i started tuning the lower zone of the pressures since i didnt want to run the car on the road yet and everything went smoothly for the first tuning stage. I then killed the engine since i wanted to fix the 5v rail issue, so i soldered the 10kohm resistor on the mmu and the board started to work again without the pc.
So i then went ahead to keep working on the tune, started the car, let it get up to temp and then... disaster struck... after running fine for the past 10 minutes it started running on 3. I immediately noticed it was because of a missing injector since i could read higher afr values.
So i took the board down and started doing some benchtest on it, finding out that one of the outputs (in this case B3 IIRC, injector 4 output), started misbehaving badly, since when measuring deltaV between pos. And inj output i could measure 1.6V at non solicited (a working output measures 1.1V) and 4.7V when solicited (where a healthy output reads Vbatt).
Now that was particularly strange, it simply didnt make sense, as the driver was still working perfectly fine on one of the internal channels, while misbehaving (but sill giving signs of life) on the other one.
So thats how i worked around it: since working on a 4 cyl i still had 2 healthy channels that i could try before having to start fisical repair.
I hooked up inkector 4 to B2 and restarted the engine (after changing outputs in tunerstudio).
It worked fine, for at least 5-6 minutes and then it happened again.
It didnt make, again, any kind of sense, and that was when, while i was looking for a solution with the engine still running, i started detaching injectors cables one at a time, starting from injector 1 (B6), which resulted in another kind of damage to the driver, since from then the output B6 is always to ground.
To recap, first board now has 3 healthy outputs and 3 bad ones, of which:
-1 (B6) is damaged by a disconnection of rhe injector while running and now is always grounded.
-2 (B3) is affected by not being able to completely ground and only measures 4.7V when solicited, but idles at 1.6v (different from the 1.1V of working outputs).
-3 (B2) same as B3.
I then ordered some new boards and in the meantime, also some new drivers to try out from mouser.
The boards arived today 19/09, before the components for the repair of the first one.
So i hooked up everything, updated the firmware to the latest build and loaded the tune, and then i fired up the engine. IT WORKED. for 10 minutes.
Then... disaster struck again... injector 2 (B5) started acting exactly as other otputs did on the first board....
I was now without ideas, only one thing was missing to test/blame. The injectors. Code 0280156023 they come from a saab 9.3 and likely have a ton of miles on their back. They all measure a bit over 16ohms (all within 5%), both measured at the injector or at the ech connector side. I decided to try a set of 0280158038, brand new bosch originals.
Again, swapped to a healthy output, hooked everything up and the loop repeated. 10 minutes it ran fine then one output lost, again. this time it was injector 4 (B3) that went.
IMPORTANT NOTE: As it can be seen, the injectors are wired individually to individual outputs, and batch injection mode is selected through software. A message is also present on the software, telling to individually wire in the injectors for batch, and that rusefi will handle everythin correlated to the firing order.
Attached the required picture.
-3 (B2) same as B3.
this seems to contradict what I see on one of the dialogs, could be an error in documentation. What's the source of above statement?
if injectors are individually wired I am puzzled how are we damaging vnld5160
I.e. my understanding is that safest mode would be sequential injection (with random phase) since that would be true individually wired with all injectors firing. As always, there is a chance that I am very confused.
Giobs
UPDATE:
I have now ran the car for 1 week after setting the injection mode to sequential (even tho, as said earlier, i'm not equipped to run full sequential due to lack of cam ssensor), and so far it's been rock solid. i don't want to call out my luck but i'll keep testing it everyday (now made 300km's) and, as i said, it now seems solid. gonna upload my tune to the dedicated section if anybody wants to take a look at it (i think it's the first tune for an M102 on there).
Giobs
Times for some news i guess.
Car has been running daily for the past month without any issue, in the meantime i added a sensor on the distributor, just rigged a bit and with a 3d printed support. Also tidied up the engine bay and wiring a bit, and put the coil pack right over the distributor for a more OE look, using VW VR6 spark cable, again with a 3d printed part. I personally think it came out great!
Still have to find a solution for a decent airbox. In the meantime i'm going to upload all my 3d cad / files to cults3d so anybody who wants to endure in this kind of conversion will have a bit of an easier life.
Giobs
Updates again!!
My exhaust manifold was cracked pretty bad so, time to go custom! Stainless headers made and fitted, it required 1.5 days of full work, but they're wonderful and now i get truly reliable o2 readings finally. The car is just so much more efficient!
Some pics:
Some pics:
OyabunG
Great write up and project. I have the M102 8V (specifically the M102.987) in my 230GE that I am going to plan to EFI soon. So, this gives me inspiration. I know you posted in the FB group for 190E and I mentioned if machining the dampener was an option to give clearance for the trigger wheel - looks like it is. Did you need to rebalance it? An alternative option is something like dbilas which has a VR sensor, bracket and trigger wheel with spacer and they mount on the outside rather than behind the crank pulley. Also Hedgehog have another option where you can put a Nissan CAS from like a S14/15 which does crank and cam in one. I do have a kit from Otto Shop in Thailand who has done a lot of EFI conversion on the M102 so it is a starting point as I learn more about the engine and the best path to take
Giobs
Thank you!
Just a bit of a run down on why i went this way.
I don't really like the solution with the trigger wheel mounted in front of the pulley simply because it's easier, if the setup isn't built correctly, to get trigger errors due to not stiff enough sensor bracket or runout of the trigger wheel.
I personally machined the damper on a lathe, mounted the trigger wheel (with everything on the lathe) and eat just a bit of material from the trigger teeth to get it concentric with the damper, this way it has no runoff and the setup with the sensor is easier.
If i had to redo it, i would just weld the trigger wheel to the pulley, it's just an extremely easier and smarter thing to do then to remove the damper, put everything on the lathe, machine it ecc. ecc.
I also like the trigger setup from the distributor since it's extremely easy to reach and to work on, even though it will run with less precision (i don't think you can fit more then 12 teeth in a diy kind of setup). I would also like to mention that 12 teeth is probably more then enough for our old sturdy engines ahah.
So yeah, IMO the best ways are the rigged distributor and / or the welded trigger wheel to the pulley.
Another small update in the meantime:
I rerun the spark cables in a different way since i was getting some crossfires and consequently kickback on startup through them (they're new but cheap) and also installed an audi Q5 2.0 air filter which is extremely high quality and works well. I tryed refitting the old air filter case but mine is pretty much destroyed from all it's previous heat cycles...
Giobs
Here we have yet another update!
just installed an idle control valve, more specifically a bosch 0280140516 out of an old audi. I'm running it in open loop with closed loop timing idle control, and i must say... what a difference it is to the way you get to daily use the car! as you can see at the moment it's just rigged up, but i'm going to design and print a support for it as soon as i can!
