[help needed] adding 2 injector outputs to UAefi ford v8 sequential injection..
Celticworksgarage
Post by Celticworksgarage »
Hi all I just received my order and am excited to get started with my build. I am working on converting my 1977 F150 "400v8" and will be using the UAefi. I am planning on using wasted spark but from what i read 8 sequential injection is possible. "simple engines" so based on that are there other outputs that can be used as injector outputs for 8 sequential? I would like 8 sequential but i have in the past ran 4 outputs to run batch fire injection. I would just prefer run sequential. I appreciate your advice, thanks.
Re: adding 2 injector outputs to UAefi ford v8 sequential injection..
https://wiki.rusefi.com/uaEFI/#faq has some info on that matter
Celticworksgarage
thank you so much for your response. I must be blind. I looked over that at least 10 times to see if i missed something haha. I appreciate your help Thank you.
Celticworksgarage wrote:
Tue Jan 27, 2026 11:18 pm
I can surely relate!
