I have a 1999 MX5. The engine is 1.8 liter the transmission is 6 speed with a LSD.
Here is my car.
And this is the type of stuff I typically do with it
I got the car little money as the crank nose had been damaged and several repair attempts had failed. The only option was to replace the crank.... that is unless you make an adapter flange like this and drive on
MX5's are underpowered? so I added a turbo
and a piggyback.
I now would like more power but I am at the limits of what I can achieve with my current set up.
A larger turbo and a rusefi ecu will hopefully get me there.
Current status: runs on rusEfi:
