Hello,
I need to help about tuner studio integration. Is there any tutorial that tells how can i communicate with tuner studio step by step. I have got the STM32f4 Discovery board with rusefi, and usb cables are connected to board.
I just need to basics... Thanks in advance...
Tuner Studio Integration
Re: Tuner Studio Integration
Is any of the LEDs blinking? How many USB cables are connected? Have you installed serial-over-usb driver?
To start using TunerStudio, you have to create a 'New Project', choose 'Custom/browse' and select our rusefi.ini configuration file.
Which version of the firmware have you compiled?
Blue LED is blinking and two usb cables are connected to computer, i have installed to the serial_over_usb driver (its looks as OK in device manager) and i've load to this compiled version ==>
and i think i'm in fault with rusefi.ini file :Srussian wrote:Just to make things easier I will also publish compiled versions at http://sourceforge.net/p/rusefi/code/HEAD/tree/trunk/firmware_binary/
The folder contains the .hex file along with the version.txt which tells how old this binary is - so far this would be done manually.
Help is on the way!izmirliss wrote:I think i'm in fault with rusefi.ini file :S
Please download firmware_binary.zip - it contains a fresh version of the .hex file and rusefi.ini is now included into this bundle. You are pretty close. When you program the discovery with the new rusefi.hex and create a new tuner studio project with rusefi.ini you should see them connected.
Thank you, i'm thinking to try this night and i'll make you know about advances
Hello friends,
Finally yesterday i've connected to Rusefi without any problem
... And i've got new questions:
1)Is there any firmware version with Manifold Air Pressure - Rotation Speed Map ?
2)Else can we make a Manifold Air Pressure - Rotation Speed map with myfloat getMap (void ) function http://rusefi.com/docs/html/map_8h.html ?
Thanks for helps...
Thanks for helps...
Its not enough. We need "speed density" algorithm implementation for quality work. But now we need good sensors reading. For example - MAP reading is too simple now, integration sensor calibrations is still in progress.Manifold Air Pressure - Rotation Speed Map ?
skype: frig_frig
@frig
I think you are talking about a system that can changes the current map values for optimum values (calculated by a algorithm) am i right?
No. To calculate engine VE using MAP and table we need Speed Density algorithm (try to google). This algorithm considers air temperature and pressure to calculate air density. If we do not do it - on any intake air themperature change we have wrong VE and wrong mixture.
Its not to hard, but at first, i think, we need configarable thermistors, MAP, crank position sensors, and other.
skype: frig_frig
P*V=m*Rs*Tfrig wrote:No. To calculate engine VE using MAP and table we need Speed Density algorithm (try to google). This algorithm considers air temperature and pressure to calculate air density. If we do not do it - on any intake air temperature change we have wrong VE and wrong mixture.
Its not to hard, but at first, i think, we need configurable thermistors, MAP, crank position sensors, and other.
m/V=P/(Rs*T)
ρ = P/(Rs*T).
R[specific] (dry air) = 287.058 J/(kg*K)
P and T both have to be in absolute terms. That means adding 101 kPa to P at sea level and 273.15 K to T.
mass of air in the cylinder = cylinder displacement * ρ * VE.
Back to reality of current implementation, what we can do pretty easily and what we should do would be a TS property that would control what is used as a key to existing table lookup.
Right now it's hardcoded to be getMaf() in https://svn.code.sf.net/p/rusefi/code/trunk/firmware/controllers/algo/fuel_map.c
We need it to use either getMaf or getMap or getTps depending on TS configuration - I have just created a ticket, anyone capable of basic programming can improve this
frig wrote:No. To calculate engine VE using MAP and table we need Speed Density algorithm (try to google). This algorithm considers air temperature and pressure to calculate air density. If we do not do it - on any intake air themperature change we have wrong VE and wrong mixture.
Can't we configure to the system with minimum and maximum values of the sensors?
