work in progress 55 pin connector 963063-2
Soldering skill: yes
Coding skill?: yes
Post by AndreyB » Sat Jul 12, 2014 1:36 am
This connector is used in plenty on German cars around late 80s - early 90s.
http://www.te.com/catalog/pn/en/963063-2
https://svn.code.sf.net/p/rusefi/code/t ... connector/
Coding skill?: yes
Re: 55 pin connector 963063-2
Post by AndreyB » Sat Sep 20, 2014 1:43 pm
This connector is available new:
Coding skill?: yes
Post by AndreyB » Tue Sep 23, 2014 12:31 pm
@ does it one more time!
@ can you do the 3D trick?
Coding skill?: yes
Post by AndreyB » Wed Oct 01, 2014 12:09 am
Just tried the paper test and realized that the connectors I've got from China has a bit different footprints:
On the bright side, both rows of pins look right. On the other side, the rows are a bit closer, and there is that 3rd row of seven groups of three pins which are all connected together - some kind of mega-ground I guess. Also the mounting holes are located differently.
I will later try to find the datasheet for this version of the connector I've got.
Coding skill?: yes
Post by AndreyB » Mon Oct 20, 2014 5:04 pm
Looks like this connector was used on some Chinese car and that's the reason why you can buy it and the matching wired plug:
http://item.taobao.com/item.htm?spm=a23 ... s=1#detail for about $10 not including shipping
jfive
Post by jfive » Mon Oct 20, 2014 7:05 pm
Interested in this. I like that it has the wires all ready too. 55 pins should be enough for any 4cyl.
Post by puff » Mon Oct 20, 2014 7:45 pm
still can't understand if it is just one piece with wires or two pieces: with wires and with legs to be mounted on board.
btw, what's the estimated shipping cost?
Coding skill?: yes
Post by AndreyB » Mon Oct 20, 2014 7:50 pm
puff wrote:still can't understand if it is just one piece with wires or two pieces
What part of 板插头线束 M154 55针 do not you understand? :) This is just the plug with the wires, the header is a separate item. At least that's the way I understand it.
I've used engtaobao.com and shipping and service fee has more or less doubles the price.
