[info] MX7-C-35PL-C11 35 pin connector
JAE 35 pin connector as used on my 2003 transmission controller module
https://svn.code.sf.net/p/rusefi/code/trunk/hardware/MX7-C-35PL-C11-connector/
https://svn.code.sf.net/p/rusefi/code/trunk/hardware/MX7-C-35PL-C11-connector/MX7-C-35PL-C11-gerber/MX7-C-35PL-C11_R0.1.zip
Re: MX7-C-35PL-C11 35 pin connector
Board ordered as 2oz (takes more time)
Seems like Oshpart has improved their processing software to merge two drill files - previously they were only using one file and it did not go well for us.
- 491b23df27cd1c04564ee206a167b3b4.png (138.77 KiB) Viewed 3339 times
board looks good
- 20161221_213641.jpg (755.31 KiB) Viewed 3271 times
That's good news. Looks good.
Finally getting back to making the harness but this board has the same silkscreen offset issue as http://rusefi.com/forum/viewtopic.php?f=4&t=687
While we are on that can we also make traces wider as well? Could be same issue with copper rings too large.
Which revision is your board marked? We have a couple out there now are we sure you have the correct revision? Just trying to make sure we are all on the same page, as I don't have eyes on it.
That's a young board, only 0.1 was ever ordered - that's the revision i have.
Oh, that's a different board. I changed the mask to 0.003, and fattened up the traces where I could. Draft committed.
I need your gerbers and your suby (once I get I larger garage)
Gerbers generated and committed.
I know what i have forgotten to ask forkb1gtt wrote:Gerbers generated and committed.
Can you please add pinout silkcreen on the back side as well? That's only needed for wiring half of the connector - the connector pads are covered by plastic.
Silk screen added, and re-committed.
Thank you! Just ordered new boards.kb1gtt wrote:Silk screen added, and re-committed.
