Jaguar VEE 12 XJS and Proteus
bill
JAGUAR VEE 12 1989 and Proteus coming up...
first pics
first pics
bill
Re: Jaguar VEE 12 XJS and Proteus
stripping out the B-A-D
what's your trigger input plan?
stock ecu has a funny number of wires like 32 pi connector?
DereksDaimler
I thought this may help its the stock ECU wiring Diagram just verify the number on the casing 16CU vs 8 CU
bill
bill
bill
soooo...
i have,
2 throttle bodies (71 mm, same as the hole in the manifold... the old throttle bodies were 60mm, so an upgrade from stock)
2 coil packs
and some spark wires
all from 2
2011 chevy impala flex fuel v6
VIN: 2G1WA5EKXB1226688 and VIN: 2G1WF5EK4B1132002
and
1 bosch TMAP from VW
i have,
2 coil packs
all from 2
and
bill
i grabbed some injectors from 2 BMW's --
325i
and 2000 BMW 528I --- VIN: WBADM6343YGV03920
the bosch EV1 injectors fit, the chevy do not
drilled the holes in the GM throttle body, and it fits okay now
325i
bill
Is it appropriate to power wash British Engineering?
dexter_lab
cleaning is necessary unless you wan to measure in mouse power instead of horse power
bill
okay so i gave it a blast of air ...
bill
wiring diagrams
A is RH bank drivers side , B is LH bank as viewed from the front.
put ETB 1 on drivers side bank
ETB
Pin Wire Color Description
A BRN Throttle Actuator Motor Control
B YEL Throttle Actuator Motor Control
C TAN Ground
D DK GRN TPS 1 Signal
E GRY 5 Volts
F PPL TPS 2 Signal
COIL on plug MAZDA
right hand to left hand when staring at the connector on the coil
a-- 12V
b-- trigger
c-- ion sense
d-- ground
PROTEUS WIRING
analog volt 1 -->MAP
" " 2 --> ETB 1A
' ' 3 --> ETB 1B
" " 4 --> ETB 2A
" " 5--> ETB 2 B
" " 6--> pedal A
" " 7--> pedal B
gas pedal from Ford Fusion
second pic
ETB
C TAN Ground
E GRY 5 Volts
F PPL TPS 2 Signal
COIL on plug MAZDA
a-- 12V
b-- trigger
c-- ion sense
d-- ground
PROTEUS WIRING
" " 2 --> ETB 1A
' ' 3 --> ETB 1B
" " 4 --> ETB 2A
" " 5--> ETB 2 B
" " 6--> pedal A
" " 7--> pedal B
second pic
bill
looks like that ETB was made to fit on this manifold ...
and perhaps a 6 speed swap?
{next year...}
{next year...}
