Jaguar VEE 12 XJS and Proteus
bill
Post by bill »
JAGUAR VEE 12 1989 and Proteus coming up...
first pics
bill
Re: Jaguar VEE 12 XJS and Proteus
Post by bill »
stripping out the B-A-D
what's your trigger input plan?
stock ecu has a funny number of wires like 32 pi connector?
DereksDaimler
Post by DereksDaimler »
I thought this may help its the stock ECU wiring Diagram just verify the number on the casing 16CU vs 8 CU
bill
Post by bill »
AndreyB wrote:
Fri May 14, 2021 1:05 am
BHAHAHHA
stock ecu is long gone....
pretty much everything is long gone...
and i have torn out the last bit of wiring for the engine...
its a virgin birth!
bill
Post by bill »
mck1117 wrote:
Fri May 14, 2021 12:12 am
a guy online has a layout for a hall sensor...
but i am open for suggestions...
what do you guys want to do??
bill
Post by bill »
soooo...
i have,
2 throttle bodies (71 mm, same as the hole in the manifold... the old throttle bodies were 60mm, so an upgrade from stock)
2 coil packs
and some spark wires
all from 2
2011 chevy impala flex fuel v6
VIN: 2G1WA5EKXB1226688 and VIN: 2G1WF5EK4B1132002
and
1 bosch TMAP from VW
bill
Post by bill »
i grabbed some injectors from 2 BMW's --
325i
and 2000 BMW 528I --- VIN: WBADM6343YGV03920
the bosch EV1 injectors fit, the chevy do not
drilled the holes in the GM throttle body, and it fits okay now
bill
Post by bill »
Is it appropriate to power wash British Engineering? :)
dexter_lab
Post by dexter_lab »
cleaning is necessary unless you wan to measure in mouse power instead of horse power :)
bill
Post by bill »
okay so i gave it a blast of air ...
bill
Post by bill »
wiring diagrams
A is RH bank drivers side , B is LH bank as viewed from the front.
put ETB 1 on drivers side bank
ETB
Pin Wire Color Description
A BRN Throttle Actuator Motor Control
B YEL Throttle Actuator Motor Control
C TAN Ground
D DK GRN TPS 1 Signal
E GRY 5 Volts
F PPL TPS 2 Signal
COIL on plug MAZDA
right hand to left hand when staring at the connector on the coil
a-- 12V
b-- trigger
c-- ion sense
d-- ground
PROTEUS WIRING
analog volt 1 -->MAP
" " 2 --> ETB 1A
' ' 3 --> ETB 1B
" " 4 --> ETB 2A
" " 5--> ETB 2 B
" " 6--> pedal A
" " 7--> pedal B
gas pedal from Ford Fusion
second pic
bill
Post by bill »
looks like that ETB was made to fit on this manifold ...
and perhaps a 6 speed swap?
{next year...}
