[rusEfi] Two stroke Efi (#14)
Number-One
Re: Two stroke Efi (#14)
Post by Number-One »
I know this tool here, but i don´t know if i can find with the gauge, most of people buy without gauge to be cheaper. Need ask tomorow.
Perhaps you can add a gauge with a Tee or similar fittings. The gauge does not need to be connected to the hand pump, it just has to be in the vacuum hose.
Number-One
Russian, need your help
After some research found some bikes and some ford and honda cars with this map signal. I belive i have this signal on my sensor.
It´s possible use this map sensor signal with rusefi?
I would guess that first we would need to convert the frequency into voltage somehow.
@, would it be possible to do that with some magic resistor and cap values on the existing RC filter before the op-amp? I believe right now we have 100R and 0.01uF or something like that.
Number-One
maybe with this
This would not be a simple circuit. 50% duty cycle means it's not just a low pass filter. I played around some with QUCS looking at adding a diode and cap to function as freq to voltage converter. So far no easy solution. I might have something that produces .9V to 1.1V, but that range is blah, and it takes some time to settle out, so it's kind of a crappy solution.
What about an external microcontroller-based DAC? I believe, the simplest solution would be to replace this sensor with another type.
The programmable way would probably require another system timer, which might not be available + some development effort.
However, looking at this sensor, I believe it has some advantages over the analogue sensors: Its readings don't change with temperature; they don't require ADC circuitry; they are probably less prone to EMI, etc.
I see, so I would need to implement the digital signal processing. That could be done.
I've just ordered myself a used Ford sensor, maybe I will have the code in about two weeks.
Number-One
russian wrote:I see, so I would need to implement the digital signal processing. That could be done.
I can do some tests with my sensor if you need.
abecedarian
Post by abecedarian »
kb1gtt wrote:This would not be a simple circuit. 50% duty cycle means it's not just a low pass filter. I played around some with QUCS looking at adding a diode and cap to function as freq to voltage converter. So far no easy solution. I might have something that produces .9V to 1.1V, but that range is blah, and it takes some time to settle out, so it's kind of a crappy solution.
Did you look at LM2907/LM2917 frequency to voltage converters?
There are several frequency to voltage converters out there. I have not looked at them closely at all. They would require a PCB layout and would need to be scabbed into the existing PCB's some how. Andrey knows that you can do thing like use a PWM output then low pass filter it to make an DAC, so he inquired if there was a semi easy way to do the same on the ADC with these signals. The problem is that these DAC's use a duty cycle to generate the various voltages, and we have a fixed duty cycle, so a low pass filter no worky for this application. The more elegant solution is to add this to the firmware.
This discussion about frequency MAF and MAP has been continued in this tread http://rusefi.com/forum/viewtopic.php?f=5&t=878
I've added Ford setting decoding into your config, but I guess your Honda sensor calibration is different?
Does your digital multimeter have Hz mode? What does it show at room pressure?
Number-One
I´m not sure, but i think i have 100hz @ idle. I will do some tests tomorow and give feedback.
By the way, how high did you rev your engine with rusEfi?
Number-One
I´m not sure, because i don´t have rev counter. I´m waiting this http://www.aliexpress.com/item/KOSO-original-speedometer-motorcycle-meter-hot-sell-motorcycle-parts-free-shipping/1852297551.html
but i can get 10k easy .
Number-One
Andrey, please check this video. I don´t have a good map value.
https://www.dropbox.com/s/4ef4ahp6jxfzyyt/3.avi?dl=0
Can you help?
Step 1: let's confirm that you are using the right input and firmware. For that, can you please hit 'enable self_stimulaton' while ECU is not on the bike, that would make simulated signal on your pin PD0 I believe (triggerinfo command would confirm trigger simulation pin)
Once you feed this simulated trigger into MAP input you should get less crazy MAP values.
Step 2: you can try feeding the value via the op-amp, this has helped me with some signals like vehicle speed sensor. Please note that my Ford MAP was producing a clean signal as is, without an op-amp.
Step 3: do you have an oscilloscope or a friend with one? That's the electronics engineering domain here and it requires some tools and knowledge for investigation :(
Sound card O-Scope would be good enough for this kind of slow signal.
rus084
Post by rus084 »
do you use frequency output MAP ?
Number-One
kb1gtt wrote:Sound card O-Scope would be good enough for this kind of slow signal.
I can get a scope, no problem.
Number-One
rus084 wrote:do you use frequency output MAP ?
Yes.
rus084
Post by rus084 »
do you activated frequency MAP sensor mode ?
rus084 wrote:do you activated frequency MAP sensor mode ?
Yes, it's in the config - as long as latest firmware & config was reset with set_engine_type 29
https://svn.code.sf.net/p/rusefi/code/trunk/firmware/config/engines/sachs.cpp
Number-One
yes, on ts i have
map input type
frequency-based map
Number-One
Update.
very nice, very nice.
Number-One
Need adjust injection starting point. What´s the command to advance it?
	 // set_injection_offset 0
	engineConfiguration->injectionOffset = 0;
that's offset regardless of engine load and RPM. There is also a tunable table of injection phase by engine load and RPM if you need it.
I've just added this field into Tuner Studio project but that would force you to upgrade to newer version.
[10:01:21 AM] ! ecu Number One Filipe: my problem now is the connection
[10:02:10 AM] ! ecu Number One Filipe: few seconds after start the engine, ts or console loose connection
is this via microUSB on the discovery or miniUSB on the Frankenstein?
